Clickin and a Clackin
I got me some noises guys. I have a clack and clack in my front end during any type of first gear acceleration or when ever i go over any speed bump or similar road hazard. Its a low speed thing nothing at high speeds unless i dont shift and punch it real hard. I have replaced driveaxles and the shocks. My front tranny mount is kinda tore up could this be the culprit, what do you guys think.
my hatch did this years ago for awhile and then one day, it was gone...never found it
by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
it is the tranny mount because my hatch used to do this until i tightend everything up
"STRICKLY MT" Shop open for business
Tuning available for S300 and Kpro
727-510-6301 Tristan
11.99@116 All Motor K24 Civic Eg6 on Drag Radials
MattBuilt
MattBuilt
if its not the mount then it may be the inner/outer tie-rods/steeringrack
you can get polyurathane inserts for the front & back mount from
Automotive engineering for less than $25 bucks........
813-377-5505
FIrst and prolly the only time ill agree with you
Do you launch it hard like dump the clutch at extreme RPMS ? check your steering rack, and steering column, tie rods ends usually dont clank unless they are broken. Check under the car at the rubber mounting points, youd know if the mount was bad youd see it but if its hitting hard enough it could clank. is it metal on metal or a thud sound ? Id reccomend having a Shop look at it if somethings broken it could not very safe to drive.
No pull ...and no its not anything on the rack or the tie rods they have been checked must be that damn mount then. The sound is more of a metal on metal click.
Id haveto hearit and locate the noise its hardto say without hearing it. look for loose bolts on the mounts. or the exhaust ! dont ask just check the hangers and the lower part of the mannifold.
