Hard Motor Break-In
on
Hard Motor Break-In
I was reading the post on the Hard Motor Break-In and i was wondering if anyone had did it and what the results were.. also i would like to know what people think about this concept
i think u should break in the motor according to how u will be driving it if u plan on racing alot beat it up on break in every motor i have built i beat up and i never have any problems just my 2 cents good luck
DONT SLEEP's penis tastes soooooo good
Guest
Posts: n/a
45 50m30|\|3 \^/h0'5 f0ll0\^/3d m4|\|y 4 m070|2 f|20m bu1ld up 70 p4|27 0u7, 1 c4|\| 73ll y0u 7h47 80% 0f 7h3 "b|234k 1|\|" 15 1|\| f4c7 d0|\|3 1|\| 7h3 f1|257 20 m1|\|u735. 1'v3 \^/47ch3d c0mp|235510|\| jump 100 p01|\|75 f|20m b3f0|23 574|271|\|g 17 70 ju57 4f73|2 4|\|d 7h3|\| 20 m1|\|5 0f h1gh 1dl3 71m3 l473|2, 17'5 47 |\|34|2 p3|2f3c7 l3v3l5. 4f73|2 53471|\|g 7h3 |21|\|g5, 7h3|23 15 |\|07h1|\|g 3l53 70 b|234k 1|\|. B34|21|\|g5 b3g1|\| \^/34|21|\|g 4|\|d h34d1|\|g 70\^/4|2d5 |23pl4c3m3|\|7 7h3 m1|\|u73 y0u 7u|2|\| 7h3 c|24|\|k. G45k375 317h3|2 534l 0|2 d0|\|'7. 7h3|23 15 317h3|2 01l p|2355u|23, 0|2 7h3|23 15|\|'7. V4lv3 534l1|\|g 15 d0|\|3 47 7h3 m4ch1|\|3 5h0p. By 7h3 71m3 y0u|2 |21|\|g5 534l c0mpl373ly (4b0u7 100-150 m1l35 plu5 4 f3\^/ \^/07 |2u|\|5), v4lv3 5p|21|\|g5 4|\|d c4m5 h4v3 4l50 \^/0|2|\| p457 4|\|y c4571|\|g fl4\^/5 0|2 f471gu3 57|235535.
Originally posted by Vapor
as someone who's followed many a motor from build up to part out, I can tell you that 80% of the "break in" is in fact done in the first 20 minutes. I've watched compression jump 100 points from before starting it to just after and then 20 mins of high idle time later, it's at near perfect levels. After seating the rings, there is nothing else to break in. Bearings begin wearing and heading towards replacement the minute you turn the crank. Gaskets either seal or don't. There is either oil pressure, or there isn't. Valve sealing is done at the machine shop. By the time your rings seal completely (about 100-150 miles plus a few WOT runs), valve springs and cams have also worn past any casting flaws or fatigue stresses.
i dont believe the process is very important as whichever way you decide to do it will 99% of the time yield the same exact results. i say just give the motor a little bit of load early so the rings can see some heat and get some thermal expansion seating. is say moderate or hard driving is the best way to do it, i am totally against grandma'ing it around to break it in. i noticed with my motor that it smoked for the first 10min after start up then wetn away while i was driving it and then when i gave the motor some load it smoked again. after a couple hundred miles no more smoking and ~6-7% leakdown across the board. just make sure the rings get a little heat early. also, make sure u change the oil/filter early
PS, this all referring to a motor with forged internals not oem. oem clearances are so tight i dont even think it matters
my new motor is getting broken in on the dyno....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
I've been seeing a lot of people doing a hard break-in with success. My last motor, I followed the Helm's break-in, which is much more gentle. Compression was perfect at 240psi across all 4 cyclinders. However, I think I'm going to try a hard break in with the next setup. 1000 miles is just too damn long.
on
ok now if your building the motor and your going to put a turbo on it...... should you put the turbo on for break in or should yo wait until its already broke in?
DSM Part Out
DSM Part Out
Guest
Posts: n/a
[QU073][1]0|21g1|\|4lly p0573d by C|2><V73c [/1]
0k |\|0\^/ 1f y0u|2 bu1ld1|\|g 7h3 m070|2 4|\|d y0u|2 g01|\|g 70 pu7 4 7u|2b0 0|\| 17...... 5h0uld y0u pu7 7h3 7u|2b0 0|\| f0|2 b|234k 1|\| 0|2 5h0uld y0 \^/417 u|\|71l 175 4l|234dy b|20k3 1|\|? [/QU073]
\^/3ll, b3f0|23 1 4|\|5\^/3|2 7h47, 1 45k y0u, \^/hy d035 17 m4773|2?
on
ok that answers my question.....i didnt think it would matter just making sure thanks for everyones comments and help
DSM Part Out
DSM Part Out
