Oil chaning...
Old Feb 13, 2004 | 12:49 PM
civicracer901's Avatar
B16ACRX
Default Oil chaning...
Ive been having to change my oil like every three weeks it seems like, I dont even drive that much. I go to change the oil and I even added some oil cleaner in the engine then drain the oil and fill it up with clean mobil one oil. Its not like iam using cheap oil just wondering if this means anything? It turns black like after a few weeks.
Does this mean like anything internally in the enigne is going bad?
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Feb 13, 2004 | 07:13 PM
Josh's Avatar
Dr. Doom
it's normal for engine oil to turn black, there shouldn't be anything wrong with your engine.
Old Feb 13, 2004 | 07:27 PM
rangcrx's Avatar
engine building &best
what normal in 3 weeks yes there is something wrong you may Be running to hot or have a Water leak somewhere it is not NOrmal to turn black so fast i change mine every 3-4weeks also but it comes out looking cleaner then when i put it in but then again mine is a brande new built engine you might want to check into everything else and keep track or your Water temp and Use,and if you burn off any when you change it,meaning are you takeing out the same amount you are putting in
i love AUTOZONE
Old Feb 13, 2004 | 07:58 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
What kind of oil are you using?
Old Feb 13, 2004 | 08:18 PM
littlehatch's Avatar
Honda
your oil will turn black.....that doesn't mean it's bad.
stock eg rear seat f/s with no rips. make an offer.
Old Feb 13, 2004 | 08:23 PM
1fasthatch's Avatar
Traction Problems
your oil should turn black after a few weeks its normal!!
www.artofspeedproductions.com
Old Feb 13, 2004 | 10:22 PM
Suspect's Avatar
Certified since '85
It is normal.....but I do suggest you go ahead begin an analysis of a water leak somewhere.
TR Hydroponics Abuser #36329
J a s o0o n: i need to get piss ass shit face fuck bag bitch ass drunk god damn
Old Feb 14, 2004 | 05:33 AM
ericmichael's Avatar
use two fingers
Ditto...
Old Feb 14, 2004 | 06:41 AM
99B16Si's Avatar
your oil will usually start to turn black at around 1000-1500miles of normal driving. if u beat the shit out of your car its obviously gonna be quicker. also large amount of blow by can cause this too.
i dont see what a water leak would have to do with anything, internal or external. an increase in coolant temp will increase your oil temp a little but unless youre running your car overheating then it wont have that much of a direct effect on your oil and youd have a lot worse of problems than dark oil.
Old Feb 14, 2004 | 07:26 AM
quickcivic's Avatar
addicted to boost
It is normal after a couple weeks of use. Mine turns blackish after about 1000 miles. If you want to be sure get your oil tested as stated already.
Later...
