Can i fix a chipped cylnder wall at the bottom of the blcok?
Is it possiable to fix a chip bout the size of a nickle at the bottom of the cylnder wall? it looks like it goes a half inch up not really that deep. It a d16y8 block on the #1 piston wall. just bought the damn thing and they said it was in perfect shape and very clean
any help would be appreicated[IMG]C:\Documents and Settings\Hybridcivic94ex\Desktop\chunk.JPG[/IMG]
pics?
check with a machine shop. they can hone it out and see where it leaves you.
when david found a hairline scratch in his he had to get work done on it again.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
just curious.... who did you buy the block from?????
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
if that is the very bottom (I can't see it too well), just smooth out the edges so nothing is sticking into the cylinder bore and put small radius's on the sharp edges. You will be fine. On d-series motors with aftermarket rods you need to notch the cylinder walls already.
Gracie Barra Clearwater
