idle air control valve
Old Feb 11, 2004 | 09:38 AM
fl_hmong_racer's Avatar
Default idle air control valve
i had a code 14 for my 94 gsr. so i got a used idle air control valve from a working 97 gsr. the car is running good compare to when i had my old one one. but the check light is still on. anybody has an idea on why its still on?
Old Feb 11, 2004 | 11:38 AM
pressuredsol's Avatar
Pleasure the do me
The iac might be bad. I went through 4 iac's before I just swallowed my pride and bought a new one. That is what sucks about them, no way to tell unless you install it. Also clean the little screens with choke cleaner. Just a thought.
Old Feb 11, 2004 | 12:18 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
HMM lets think 94 and 97 OBDI and OBDII there are subtle sesor differences sometimes and IAC's are a bitch ! if they arnt new i wouldnt bother with a used one !
Old Feb 11, 2004 | 05:41 PM
xTegzy's Avatar
yeah i reseted everything. but it was still on. i was thinking bout the obd1 and obd2.. so could that b it? but i got the idle air control off a gsr that was still running everyday, so i don;t think that its bad.
xTegzy's Avatar
thanx
Old Feb 11, 2004 | 06:40 PM
try checking the code see what it is ! i had an IAC code and i had a broken wire running to the map sensor !
