Honing Grit?
Old Feb 10, 2004 | 10:29 AM
Janky99's Avatar
Honda Guru
Default Honing Grit?
Hey I just whent and picked up a honing tool from the local auto parts store, and it came with 300 grit honing blocks on it. Is this an ok grit to finish honing with? or should i go with a higher grit to finish it? all helps appreciated -Ben
Old Feb 10, 2004 | 06:47 PM
Janky99's Avatar
Honda Guru
Too late, i got the blocks, couldnt find the other type anywhere, i put the pistons back in tonight i hope this thing runs with the 300 grit hone job, i didnt seem like they were too deep in the walls. -Ben
Old Feb 10, 2004 | 09:21 PM
rangcrx's Avatar
engine building &best
that is a perfect grit as long as you do it up and down and dont keep it in one place
i love AUTOZONE
Old Feb 11, 2004 | 02:42 AM
Janky99's Avatar
Honda Guru
alright, thats cool thanks, does anyone know how many miles ill need to break it in for? and if it will smoke for sometime? thanks -Ben
Old Feb 11, 2004 | 09:10 AM
Jeff240sx's Avatar
Cpt. Negative
If the rings are sealing, it shouldn't smoke. Break-in time will be 1000 miles, like a normal rebuild.
-Jeff
** This space reserved for someone else's witty quote **
Old Feb 11, 2004 | 10:16 AM
Janky99's Avatar
Honda Guru
Im using all stock internals from a Z6 for an A6 block, i have another question... whats the rev limit on a z6? thanks alot -Ben
Old Feb 23, 2011 | 02:39 PM
shanefoster's Avatar
You have providing good info on honing grit. According to me higher grit is always better then others. You should go with higher one that gives you better performance. Thanks.
Old Feb 23, 2011 | 05:57 PM
JoKiE crx4294's Avatar
popeye built!
^^^^nice post broski...
Can't spell strength without tren
AAS...It's whats for dinner
