mini me timing belt question
Old Feb 9, 2004 | 06:01 PM
Gringo003's Avatar
B.B.C
Default mini me timing belt question
ok i just put my timing belt on my mini me which i got a timing belt for a d16y8 head which i have and when i put it on and tighten it up it moves over from the tdc possition and when i tighten the tensioner it is very loose still how loose is it suppose to be i mean i could prolly take the belt off with the tensioner tighened all the way any help would be appreciated
Old Feb 9, 2004 | 06:11 PM
crix's Avatar
:mugen member:
every time I did a mini me swap I used the 1.5 timing belt(shorter)
the y8 is longer & will never tighten up on a 1.5 block.....my advice would be to get a 1.5 t-belt........
Old Feb 9, 2004 | 06:56 PM
Gringo003's Avatar
B.B.C
well i kinda got it figuredout now and it is tighting it is there anyone out there that wants to do the timing properly for me lol let me know
Old Feb 9, 2004 | 06:59 PM
Gringo003's Avatar
B.B.C
i thought you had to get the timing belt of the head you got like a y8 head y8 timing belt i dont know this is what i have been told and it would suck to be wrong and have to buy a new one will it work with the y8 timing belt or am i screwed and have to buy an d15 timing belt
Old Feb 10, 2004 | 05:10 AM
jdmef9's Avatar
i had to buy the z6 timing belt
josh
14.7@91 sohc all motor
Old Feb 10, 2004 | 12:12 PM
crix's Avatar
:mugen member:
I can put the motor in time for you.....and do you still have the old timing belt ?
Old Feb 10, 2004 | 12:42 PM
Janky99's Avatar
Honda Guru
Im using the z6 tmiing belt with no problem, i was told to use it so i am. -Ben
Old Feb 11, 2004 | 06:20 PM
R91Si's Avatar
i used a 1.5 belt...d15b7 block/d16y8 head...i think a cx belt works
Old Feb 11, 2004 | 06:43 PM
Gringo003's Avatar
B.B.C
so a y8 timing belt wont work ??? i am using one
Old Feb 11, 2004 | 07:18 PM
SEEKERone's Avatar
Trialed for Treason
1.5L block with vtec head use 92-95civic VX t-belt
1.6L block with vtec head use 92-95EX(Z6) or 96-00 (Y8) belt
the Z6 AND the Y8 belts are exactly the same size...but Y8 is slightly less $$
Liar, you couldn't cut me deeper with a knife if you tried
