CRX: Engine Not Starting...
Old Feb 10, 2004 | 07:07 AM
emohatch's Avatar
Guest
timming
Old Feb 10, 2004 | 08:36 AM
40ozCasualty's Avatar
shift_lock
We have another issue, We have a DX distributor, is the Si any different than the DX one? Its still backfiring from the intake manifold, Which is a strange sight to say the least...
Old Feb 10, 2004 | 09:02 AM
Old Renegade's Avatar
Cool Runnings
yeah if the timing is way off there will be valve to piston contact, but if it is off little bit it will miss sort of like a sputter and idle bad in some cases like it wants to stall and it will run like crap. firing order is the position of where the wires coming from the plug connects to the distributor cap. for example #1 spark plug wire may connect to the upper rear connect point on the dizzy #2 might connect to the lower rear and so on. mostly on hondas its either clockswise or counterclockwise, example 1,2,3,4 facing the front of the engine or 4,3,2,1 facing the rear of the engine. your best bet is to find someone with a si and look to see how thier firing order goes, also you might want to use the dizzy that came with the head.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Feb 10, 2004 | 09:24 AM
shift_lock
Success! It was the spark plug wire order on the distributor. Done up the way Ian said, and she started purring like a kitten. :o
Here's a picture for your enjoyment, I'm really excited right now.
Old Feb 10, 2004 | 09:56 AM
rangcrx's Avatar
engine building &best
very good
i love AUTOZONE
Old Feb 10, 2004 | 12:57 PM
shift_lock
Eh, A little more trouble. The motor starts and everything, But there is play in the drive plate, And we think that its making a really nasty knocking sound. The motor isn't knocking its the drive plate, We think. So, do we need to drop the transmission and tighten the drive plate?
Old Feb 10, 2004 | 03:00 PM
  #17 (permalink)
Cool Runnings
Default car what type
thats good your car is running glad to help, is the car auto or stick. are yuo sure that is a si cause the pic looks like a dx motor.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Feb 10, 2004 | 03:01 PM
  #18 (permalink)
shift_lock
Auto
Old Feb 10, 2004 | 03:06 PM
  #19 (permalink)
Cool Runnings
you will have to drop the tranny cause it looks like what is called a flex plate might be loose or you might have a bad torque convertor.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Feb 10, 2004 | 03:23 PM
  #20 (permalink)
shift_lock
the motor block says d16a1. Ya i guess we will have to drop the tranny. The block and head is a si but the body is a dx.
