type R dash into ef9 civic
how hard would it be to put a type r dash and center consule into a ef9 civic? Thanks
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
it actually doesnt take that much too put one in but you will either have to modify or just not use your door panels because your doors wont close with the integra dash.
i saw a big write up on it somewhere with lots of pics, ill have to find it again.
thanks. If you could find the info it would be great. thanks again
see this is what it looks like did he cut the door pannel in half or something?
Yes, he cut the door pannels to fit around the edges of the dash ( could have looked good if he took his time, looked kinda ghetto... almost looked like he used an exact-o knife)... this guy was a the last CRX meet in Orlando...
so is it a direct bolt in. will the holes line up? i know i will have to mod the door pannels but other than that. Thanks Does anyone know where I can pick up a itr dash?
no its not a DIRECT bolt in but very minor adjustments have to be made. the write up i saw on it the guy made 2 brackets to bolt on (just straight piece of steel or something with holes drilled in them) to hold the sides to the frame and had to bend a piece of metal around where the cluster goes.
im still trying to find it.
I looked on clubsi.com and did a search with no luck. I want to thank you guys for tryin.
