Turn signal lights go on when I push the brake?
SEEKERone
[quote]if these lights are acting up only when you press the brake, another possibility is to check to see if somebody put the wrong type of bulb in the brake lights. the correct bulb should be a dual(two) filament bulb...if someone forced a single filament bulb into the socket, then power backfeeding could cause something similar to what you vaugely described.[quote]
Thank you that was it
