250 lb/ft torque..easily obtainable?
Old Jan 30, 2004 | 06:16 PM
ItsSoDookie's Avatar
Default 250 lb/ft torque..easily obtainable?
torque...is something all H badged cars lack from the get go
the only way to produce torque in our cars is boost. so here is my question
i want ATLEAST 250 lb/ft. of torque, on 93 octane
what i have now:
sfp cereramic coated manifold,
tial 40mm wastegate
precision sc 44...
hopefully hondata or uberdata(props to vertigo)
intecooler and boost controller have not been bought/chosen yet
here are the basic specs on the engine
basic pr3 head with slight bowl and port work from rlz engineering
stock b17a cams,,, 264 intake/274 exhaust i believe
new oem valves, itr springs , skunk retainers
and now here is the problem
block choice.
the car has an original b17a..but ive been think about using a diffrent bottom end, b18c or b18b
you think 250 lb/ft. torque is possible with the 1.7 in street use?
(pump gas, low psi)
or should i go with one of the 1.8's?
please, dont start an ls/vtec debate over this
Old Jan 30, 2004 | 08:02 PM
Rdline1's Avatar
Hi Hi Hi?
smaller turbos make more torque faster too.....
98 Camry w00t! (daily ride)
91' Eclipse GS-t (she's alive!!)
AOL IM: usfbull49
Originally Posted by Frankie
When a jelly fish comes out of my ass, I'll take pics.
Old Jan 31, 2004 | 09:20 AM
woot woot...over 330hp? good. as soon as i sell my 1.7 i think ill go with a sleeved ls.
Old Jan 31, 2004 | 11:49 AM
tegasaurus's Avatar
vtec where?
I have a completely stock LS on 93 octane w/ 270 ft/lb's on low boost. I'll keep you posted on high boost tq #'s, after next weekend. With lower compression engines, running a high level of boost, will net you high tq #'s. For 250lb/ft you do not need to sleeve or bore over a B series to a 2.0L, that is unnecessary. Of course displacement is the obvious answer for increased output, or torque, but for what you are looking for you can achieve that with far less.
99 gsr
- B18b -
349 whp - 299 ft/lb
Old Jan 31, 2004 | 12:05 PM
tegasaurus's Avatar
vtec where?
T3 T04E 56 trim with .63a/r
The boost level is irrelevant, I tuned by tq. What I have now will be low boost, and I have yet to tune for higher boost. Both will be on 93 octane.
99 gsr
- B18b -
349 whp - 299 ft/lb
Old Jan 31, 2004 | 02:15 PM
specie's Avatar
Sam, you got a nice project going. Is this going in the 2nd gen Integra?
It'd be easier to get that amount of torque from a 1.8 ls block than the 1.7. Make sure to get forged pistons.
Old Jan 31, 2004 | 06:54 PM
tegasaurus's Avatar
vtec where?
Originally posted by Cronic
I was not aware Garret made a 56 trim(besides a GT30). Boost level is most certainly relevant. I've never known anyone to "tune" by boost.
Most tune by A/F, EGT, and / or timing. However... I didn't even ask how you tuned man. Simply what turbo, and how much boost.
Boost is irrelevant in determining anything about my specific setup. Depending how aggressive the tune, boost and corresponding power would vary extremely.
But if it truly helps. . . 14 psi
and you have to "tune" by boost. (specifically map pressure & rpm)
and yes obviously A/F would be how to tune fuel, and one of the ways to see the direct effects of timing in boost would be egt
99 gsr
- B18b -
349 whp - 299 ft/lb
