TPS adjust.. Need someone..
Old Jan 27, 2004 | 05:24 PM
civicracer901's Avatar
B16ACRX
Default TPS adjust.. Need someone..
I just bought a brand new engine harness from HONDA BRAND NEW!! I just finished installing it. Its for a 88 crx si with a b16a1 and it elimitated like 99% of my problems tonight and took a huge load off my back.
I just also want to know what good prices Bert-O has and a good person to deal with. Thanks again bert.
One problem though. Iam still throwing a tps code(7) this is a obd0. I need somone to get rid of this code. THe sensor seems fine. I think awhile back I know I bumped it pretty good enough iam sure to throw it out of wack and throw a code. I need someone to come over and adjust this for me. CRIX?? etc.. let me know. thanks
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Jan 27, 2004 | 06:54 PM
integra's Avatar
90% grind 10% sleep
could have the plug backwards?????
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 27, 2004 | 07:26 PM
crix's Avatar
:mugen member:
make sure the new TPS is centerd when bolt it down,reset the ecu & try again.....
Old Jan 27, 2004 | 07:29 PM
aaron1017's Avatar
is not Rotarded anymore!
I believe it should be 0.5 Volts @ 10% open and 4.5 Volts @ 90% open.
LS1/T56 Heads Cam 1994 FD
Old Jan 28, 2004 | 06:36 PM
R91Si's Avatar
should be .5 volts closed throttle and around 4.5 volts at full throttle with a steady rise (no drops in voltage from closed to open)
Old Jan 29, 2004 | 11:52 AM
B16ACRX
anyone have another b16thorttle body with a tps I can have or use?
