What Type Of Engine Management?
What Type Of Engine Management Should I Use For A Mini Me Swap Turbo Setup?
D15B7 Block
D16Y8 Head
88' CRX SI ECU
TD05H Turbo
Stock CRX SI Injectors
Stock CRX Fuel Pump
Need Help!
D15B7 Block
D16Y8 Head
88' CRX SI ECU
TD05H Turbo
Stock CRX Fuel Pump
Need Help!
Check out Uberdata.
http://www.ecimulti.org/uberdata/
Forums @ http://www.ecimulti.org/uberdata/forums/
AIM: IntegrVTEC <-best way to contact me.
Guest
Posts: n/a
Hondata. -- On a side note, you will want larger injectors, and an upgraded fuel pump if you plan to push more then 7-8psi.
Also, with the 1.5 bottom end, you will not be able to rev over 6500, else bewarned you will spin a bearing. The bottom end is not balanced.
after talking to some very reputable people at the show and shine, i am currently *looking* into zdyne for my mini me high compression obd0 swap. no converting to obd1. no burning chips. just use your laptop and go. like any thing else, it's expensive.
www.zdyne.com
www.zdyne.com
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Guest
Posts: n/a
Zdy|\|3 \^/0|2k5 g|2347 1f y0u 4|23 574y1|\|g u|\|d3|2 15p51 4|\|d 7400|2pm. 1f d01|\|g 50m37h1|\|g b3y0|\|d 7h053 p4|24m373|25, H0|\|d474 4|\|d 07h3|2 574|\|d 4l0|\|35 4|23 v3|2y g00d. Zdy|\|3, b7\^/, d035 |\|07 |23qu1|23 4|\|y ch1p bu|2|\|1|\|g \^/h47503v3|2. |\|07 l1k3 bu|2|\|1|\|g 4 ch1p 15 5uch 4 hug3 71m3 c0|\|5um1|\|g p|20c355....
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Like Vertigo said look into Ghettodyne or Turbo Edit or if you want to wire to obd1 look into his rom editor he wrote Uberdata. I'm personally using Uberdata on my car and several others. Good stuff.
Gracie Barra Clearwater
