stuttering b16a obd0
Old Jan 26, 2004 | 06:40 AM
R91Si's Avatar
Default stuttering b16a obd0
car stutters at part throttle...its good at full and good idle...pulled battery and let it sit and car runs great again!!it only lasts couple of days then it starts f*$%in up again!!!!!what the hell????
Old Jan 26, 2004 | 07:10 AM
KJ's Avatar
KJ
bored at work
The obd0 pr3 and pwo ecu's are real picky about the o2 sensors. Are you running both of them? If so try switching the positions of the two sensors. Sounds stupid but it works sometimes.
Also if anyone you knows has a mugen chipped ecu or some other chip that eliminates closed loop try that.
Old Jan 26, 2004 | 07:45 AM
R91Si's Avatar
ive got 1 o2 running and at the ecu it is jumped so that the o2 is sending signal to both inputs on ecu
Old Jan 26, 2004 | 08:27 AM
Fermunky's Avatar
King Ding-A-Ling
May sound weird, but my buddies integra was doing the same thing. Runs good at full throttle and idle, only in between it would sputter. Turned out all we had to do is turn his distributor a little (I thikn advanced) and it cleared it up. Just a suggestion towards an easy solution...
Old Jan 26, 2004 | 02:29 PM
styles999's Avatar
Powered ByYo Mommas Mouth
also, it might sound dumb, but mine did it ...clean the FIACV (fast Idle air control valve), it cleared mine up. and watch out when you take it off, especially if your car was warmed up, hot anti-freeze isnt nice to the skin. lol.
Old Jan 26, 2004 | 03:24 PM
Old Renegade's Avatar
Cool Runnings
Listen to kj this guy definately knows his stuff. i also have a first gen b-16a pr3 and ran into the same problem, i told him what you said and he told me the same thing, so i swapped the o2 sensor wires around on the ecu and never had that problem again.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jan 29, 2004 | 04:39 PM
R91Si's Avatar
still doin it...o2's dont work untill closed loop...my car does it open loop and closed loop...i replaced distributor and it still does it
Old Feb 3, 2004 | 04:14 PM
redcrx187's Avatar
ALL MOTOR LS/VTEC
i have only one o2 sensor on a pr3 and i have no problems
