:? still leaking afte new distributor?
have you pulled off the cap to see if the oil is leaking past the seal inside the dist housing. this is a common problem.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
sorry forgot you just put in new one
K series on crack
S D M
K series on crack
S D M
im not sure what you mean by the little screw? explaine to me location ?
K series on crack
S D M
K series on crack
S D M
Bottom of the dizzy. Its a little plate thingy held on by a little phillips screw. Under the plate looks like a little hole. On my old one I put JB weld in the hole thinking it would stop the leak /LMAO. Then it started to leak right into the dizzy cap. When i took the cap off the whole thing was filled with oil.
you didnt take out the oil controll jet out of the block?? that could be why does vtec still work or is it not actavating let me know how this swap runs i am gettigng ready to do one myself so let me know what you think and if it is worth the hassel or not
