How to view code for check engine light. 96 accord
Old Jan 25, 2004 | 12:44 PM
ZDriver96's Avatar
Default How to view code for check engine light. 96 accord
I looked all over the car and found now port to plug an OBDII scanner into to check my Check engine light?
It has to have one its an OBDII...
where is it???
If not isnt there a plug next to the ECU on the passenger side kick panel i can check..
I was under the impression to that there would be a plug down there with a 2 pin connecter and to loop that connector with a paper clip, and then put the key in the ignition and watch for the code to flash on the check engine...
By the way im trying to read a code that i believe is for my transmission.
anyone one got an instructions link?
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Jan 25, 2004 | 12:46 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
under the ash tray or behind the consoule on the right hand side ! i think its under the ashtray though !
Old Jan 25, 2004 | 08:26 PM
aaron1017's Avatar
is not Rotarded anymore!
Default Re: How to view code for check engine light. 96 accord
DAMN Double POSTS!
LS1/T56 Heads Cam 1994 FD
Old Jan 25, 2004 | 08:28 PM
aaron1017's Avatar
You are correct, here is a decent instruction page. I know it for an Acura CL, but the Accord and CL are 90% the same.
http://home.insightbb.com/~niedejb/refs2.html
Old Jan 26, 2004 | 12:38 PM
ZDriver96's Avatar
I got it... Its a tranny code... the Overdrive 4 display on the gauge cluster indicates its a tranny code 15...
The Check engine light blinks consitant 7's but i dont think it means anything??? just to indicate its displaying a code for the tranny...
Now i gots to go find a site or get the book to see what code that is.
"SLOW LT1"
Blue 2005 Acura TSX
Old Jan 26, 2004 | 01:16 PM
aaron1017's Avatar
I am looking right now for you on my electronic manual.
Old Jan 26, 2004 | 01:24 PM
ZDriver96's Avatar
awesome thanks bro... saves me a trip to discount auto to look in there haines book.
"SLOW LT1"
Blue 2005 Acura TSX
Old Jan 26, 2004 | 01:41 PM
aaron1017's Avatar
Go here... http://web.tampabay.rr.com/aaron1 there is a foler with your name on it!
I have the Mitchell On-Demand System for computers if you want it. I only have the CD that contains the Honda/Acura files. Just give me a blank CD and I will burn it!
Old Jan 26, 2004 | 04:38 PM
na200whp's Avatar
Powered by BOOST
here is a quick tip for others that have this problem . under the steering colum cover there is a sticker that tells you the location of the obd2 port to plug a scanner in.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Jan 26, 2004 | 05:44 PM
crix's Avatar
:mugen member:
the code 7 is the TPS sensor(throttle position sensor) .......
