Honda does go into park, reverse or Neutral
Old Jan 20, 2004 | 04:20 PM
Levi's Avatar
Default Honda doesn't go into park, reverse or Neutral, need help fast!!!
say the topic states, I have problem I thought was a easy fix, but seems to be more invloved.
I just got a nice clean 88 Honda Accord LXi 2.0 FI Automatic. $250 113,000
The car shifts fine through all the drive gears. I cannot get the car out of drive, I pull out the console, and the shift cable is conected to the selector. I looked under the car and the cable is in the trans.
The lights in the dash indicate I am getting into park, and reverse, but will not pull back past D4 on the selector, kinda like its held up.
Does anyone know what could be wrong here.
custom parts is our perfection.
Old Jan 20, 2004 | 04:46 PM
Levi's Avatar
Shit, it must be too old?
Old Jan 20, 2004 | 05:06 PM
na200whp's Avatar
Powered by BOOST
broken shift cable? the gauge only shows what position the selector is in . meaning if you put the selector in reverse there is a switch on the selector turning on the r light on the dash but the cable going out to the transmision which is attached to the selector is what is putting the trans in reverse.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Jan 21, 2004 | 12:34 PM
Levi's Avatar
I could check this by pulling back the boot on the trans and have someone shift it inside the car, this would show no movement? is this the correct method to check.
Old Jan 22, 2004 | 02:20 PM
Levi's Avatar
I really need some help from the Honda crowd here.
Old Jan 22, 2004 | 07:43 PM
integra's Avatar
90% grind 10% sleep
damn automatics
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 22, 2004 | 10:47 PM
crix's Avatar
:mugen member:
you could check it this way,& also check for an adjustment on the cable
it may have slipped( not sure if it has an adjustment)if you want any help pm me .......fixed a few LX-I s before
Old Jan 24, 2004 | 09:37 AM
Levi's Avatar
The cable is held in place by a plate with a single bolt. Once I removed the bolt, and the case, I could see the cable, internally I could see a nut for maybe adjustment, I had a friend moved the selector, and got plenty of movement, I think and I could here it chnaging the gears, making a click for each gear, but after I put it back together, its still not working WTF?
Scott, check your PMs.
Magic said they would check it for free, but I doubt that one..
Old Jan 25, 2004 | 05:33 AM
Levi's Avatar
I guess I am off to the shop to get it looked @ I must be stupid..
Old Aug 25, 2005 | 10:38 AM
hothondaboy88's Avatar
could u just sell the starter an if so how much would u sell it for
