battery light comes on
Old Jan 17, 2004 | 09:28 AM
jdmef9's Avatar
Default battery light comes on
it comes on then it shuts off. it doesnt stay on all the time, and when i get on it, it doesnt turn on(battery light) usually. any body have any idea what is causing the light to come on. i checked the alternator by removing the positive battery cable when the car is on.
thanx josh
josh
14.7@91 sohc all motor
Old Jan 17, 2004 | 09:31 AM
99B16Si's Avatar
slipping belt? have discount check your alternator
Old Jan 17, 2004 | 11:20 AM
jdmef9's Avatar
thanx bro
josh
Old Jan 17, 2004 | 11:42 AM
Janky99's Avatar
Honda Guru
bad motor ground, or no ground at all, make sure the ground that goes to your valve cover is on all the way
Old Jan 18, 2004 | 08:28 AM
User1578's Avatar
My blowoff valve goes Moo
Mine came on when the belt to my alternator broke. Your belt is slipping...
AIM: IntegrVTEC <-best way to contact me.
Old Jan 18, 2004 | 11:16 AM
jdmef9's Avatar
so how do i fix the slipping belt problem
thanx
josh
Old Jan 18, 2004 | 11:25 AM
91IntegVtec's Avatar
i say check engine ground wire on valve cover as well
Old Jan 21, 2004 | 02:29 PM
Janky99's Avatar
Honda Guru
yea +1
Old Jan 21, 2004 | 07:36 PM
j0shth3j3w's Avatar
Everything is for trade.
keep it simple
1. check the all 3 grounds
2. clean your battery posts
3. if the belt to your altenator turns more than 180 degrees its lose it has an adjustment bracket on it so you can easily adjust it
4. go to any auto parts store and have them check your battery and alternator
Josh
Just text me.... 813-785-5222
Old Jan 21, 2004 | 07:52 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
Originally posted by janky_crx
keep it simple
Josh
+1 +1 +1 I like you,
