Custom Turbo List
ok i finally finshed researching and i would appreciate it if u guys looked at my list and set me on the right track..
Car 94 ls integra
103,000 miles
b18b1
Compression test numbers coming sooon
250 - 300 whp goal on stock internals
Turbo
exhaust manifold gasket
B Series 4 into 1 Cast Iron Turbo Exhaust Manifold
turbine exhaust gasket.
Turbonetics T3/T04 Turbocharger
Wastegate gasket.
Tial External Wastegate 38mm
Wastegate Dump Tube
turbo down pipe, gasket
2.5" Exhaust Down Pipe
exhaust donut
Hi Flow CAt\Test pipe
Elderbrook Intake Manifold
Intake Manifold gasket
Intake Air Filter Assembly
K&N Air Filter
90degree Elbow
Spearco Front-Mount Intercooler
HKS Super Sequential Blow-Off Valve
bov gasket
8-9 Blue Silicone Couplers and Clamps
walbro intank fuel pump
High Pressure Fuel Line
Hondata Fuel Management System
AEM Fuel Rail
or
440cc Lucas Fuel Injectors
Stainless Steel Braided Oil Feed (-10 SS line)
Line w/ Fittings Assembly
earls fittings
Oil Return Line (-8 SS line)
oil pan gasket
Apex-i AVC Type-R turbo boost controller (digital)
greddy Turbo Timer
boost guage
a/f guage
Fuel Pressure Gauge
egt guage
2 Bar Map Sensor
Missing Link
MF2 ERL 3D Map Injector Controller
High Pressure Silicon Hose
Neccessary Vacuum Tee's
Neccessary Vacuum Lines
Zipties
Future upgrades
****cometic turbo gasket, stock thickness
****GReddy 2mm Metal Head Gasket
MSD Boost Timing Manager (BTM)
MSD 6A
MSD Blaster 3 Coil
MSD Pro Cap
NGK Blue Wires
eagle rods
JE 9.8:1 Pistons
Block Guard
Sleeve Block
Fluidyne Ultra Thin Radiator w/ Fan
Car 94 ls integra
103,000 miles
b18b1
Turbo
Wastegate gasket.
Wastegate Dump Tube
exhaust donut
K&N Air Filter
90degree Elbow
bov gasket
AEM Fuel Rail
or
earls fittings
oil pan gasket
greddy Turbo Timer
boost guage
a/f guage
Fuel Pressure Gauge
egt guage
2 Bar Map Sensor
Missing Link
Zipties
Future upgrades
MSD 6A
MSD Blaster 3 Coil
MSD Pro Cap
NGK Blue Wires
eagle rods
JE 9.8:1 Pistons
Block Guard
Sleeve Block
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
Get a 3" downpipe and exhaust all the way back, get the test pipe instead of a high flow cat.
Edit: Misread something.
fisrt off listen to Vito, 3" dp and 3" exhaust with a test pipe for sure! If you are going to upgrade your fuel do it all, not a fuel rail OR injectors. you need both of those, if anything get the injectors though. other than that it looks to me like you still have some research to do on manifolds and what not, Keep researching and dont buy crap parts! thats the best suggestion i have! good luck
B18C1 build: Looking for 400+on pump gas. slowly coming along
These are my suggestions. 280WHP - 300WHP on a stock bottom end is a good goal.
* Inline Pro or LoveFab log exhaust manifold
* Precision SC34 turbocharger
* TiAL 38mm wastegate
* TiAL blowoff valve
* Precision AS 1025 intercooler
* 2.5" downpipe to 3.0" test pipe to Apexi N1
* GEM blockguard
* ARP head studs
* Hondata s100
* Precision 525cc injectors
* NGK spark plugs
That's all I recommend doing. That setup will make 300WHP.
* GEM blockguard
* ARP head studs
* Hondata s100
* NGK spark plugs
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Guest
Posts: n/a
* GEM blockguard
* ARP head studs
* Hondata s100
* NGK spark plugs
* GEM blockguard
* ARP head studs
* Hondata s100
* NGK spark plugs
-Keith
you dont seem to kno wtf you are talking about, and prolly just listed a bunch of parts you saw in your superstreet magazine. Do not turbo your car. Research first, and dont fall into false hype like precision turbochargers.
High pressure fuel line + missinglink + hondata + 440cc injectors + 2 Bar Map Sensor + MF2 ERL 3D Map Injector Controller?
Why are you going to put a 2bar map sensor on, just to block off the boost with the missing link, rendering hondata useless and relying on a gay MF2 to control your fuel. You dont need high pressure fuel line or an aem fuel rail.
All you need to achieve your goals is:
-T3/T4 (dont waste your money on that overpriced precision) or a large T3.
-GM 3Bar Map sensor
-Hondata or uberdata
-tial or deltagate wastegate
-any bov
- any front mount intercooler
-any manifold
-3" turboback
-550cc injectors
-tuning
If you dont fall for the hype you can save alot of money. I built my kit for $600 and I should be able to hit 300hp with a 3bar and larger injectors.
-GM 3Bar Map sensor
-any bov
-any manifold
-3" turboback
-550cc injectors
-tuning
Hype? No. A little bit of a bandwagon? Yes but that's not to say they don't make a good product. For $650.00 Precision turbochargers are the best money can buy. Quite a few members on this board have Precision turbochargers and are very happy with them.
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Guest
Posts: n/a
Also, Hondata isnt just a fuel managment system, it's an entire engine management system, also, ditch the MSd crap, you wont need any of it.
a 3" downpipe may not allow you to keep your AC.
Don't need the block guard if your sleeving the motor either, i wouldn't use one anyway.
Or the AEM fuel rail.
thanks guys the reason i posted my list was to makes ure i was on the right track. i looked at parts for prebuilt kits and then i slowly researched the parts picking and adding what all i needed.
The Myspace Page
made.
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
You have a decent setup going but like some other people have pointed out some of the things you won't need and others you just don't want to put on. If I was you I would go with the hondata, 440cc injectors or better, cut out the missing link because that just blocks your computer from seeing boost and you want hondata to see the boost. I believe the hondata you want is the S200B. Just keep researching and talking to people who know a lot about turbo applications. It will help out a lot I promise...
-13 Suburu Impreza WRX
-10 Honda CBR1000RR (for sale PM me)
-07 Nissan Frontier CC (sold)
-99 JDM ITR DB8 (4dr whore) sold
-98 Acura Integra GS (Go Slow) sold
-04 Ford Ranger Ext Cab Step side (traded)
-03 Kawasaki KFX400 (sold)
-05 Kawasaki KFX400 (sold)
-02 GSXR 750 (sold)
-04 Triumph Daytona 600 (sold)
-02 GSXR 750 (sold)
