Idle problems
ok, for no apparent reason, my idle just started messin up. I have a 95 hatch with a b16 and for some reason my idle now jumps from 1000-1500rpms continuously. before it would stay at a constant 750-800rpms. What might the problem be? how can i fix it?
vacum leak?
throwing any codes?
It's most likely the Idle Air Control Valve, the Throttle Postition Sensor, the PCV Valve, or just a vacuum leak.
idle
Originally posted by Vito_Corleone It's most likely the Idle Air Control Valve, the Throttle Postition Sensor, the PCV Valve, or just a vacuum leak. |
my friend had the same problem, the rps jump up and down, then settle. we found out it was his vacum.
Was it a Hoover?
Originally posted by Vito_Corleone Was it a Hoover? |
try cleaning out the screen on the Idle control valve with carb cleaner
you will need to remove it to do this.... |
https://www.tamparacing.com/forums/s...hreadid=127547
simple search... i didnt even have to go into the search function... this is just like 10 post down... please read before making a new thread... -Keith |
