oil pressure sender?
i just got an oil pressure gauge and all the lines and fittings but cant find oil pressure sender anybody know? i did a little research but found nothing so i figured id ask before stressing myself out thanks alot
its the only thing around the filter that you could hook anything up to, but if i remember correctly its on the right side. you might want to take off the oil filter for easier installation.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
make sure that you do not install a T fitting straight into the block, but rather an -AN style fitting to an oil line that goes to a union block where the sensors will be housed. The T-fitting will eventually crack yourblock, creating devestating results. Mount the T fitting ont he firewall with the senders on opposite sides and the line going straight into the block.
RIP Tim. i miss you, buddy
