head swap
Old Jan 7, 2004 | 01:54 AM
LSC5.0HO's Avatar
FIRI VP
Question head swap
Well, I figured out what was wrong with my d15B1. 1 of the exhaust valves had a quarter of it missing. So I went to junkyard and pulled a head off of a B2. My friend told me if I got the head and ECU, it is about a 20hp upgrade. Only, I think it is slower. I even swapped the ECU's a few times and there is no difference. What's the deal...is this kid BSing me???
Old Jan 7, 2004 | 02:05 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
D15B1 1.5 8V SOHC PGM-FI 1493 70hp@5500rpm 83tq@3000rpm 88-?? Civic
D15B2 1.5 16VSOHC PGM-FI 1493 92hp@6000rpm 89tq@4500rpm 88-91 Civic DX/LX
I found two stats for the D15B2, one is the HF and one is the DX, one being 62 and one being 92, the difference is, other than gearing, the DX head is a 16 valve. Is that the head you swapped a 16 valve?
Old Jan 7, 2004 | 03:50 AM
mtber's Avatar
Never listen to your friends, lol
Old Jan 7, 2004 | 04:56 AM
Walter's Avatar
Im as loyal as my options
+1
blah blah blah
Old Jan 11, 2004 | 05:54 PM
LSC5.0HO's Avatar
FIRI VP
both of them were 16 valve
FIRI...The Right Attitude!
Old Jan 11, 2004 | 09:23 PM
SPORK Racing's Avatar
when you do that swap you have to swap the intakemanifold and throttlebody otherwise your just tring to suck more air into that straw sized intake and manifold, which is restricting the air flow, so swap out the IM and TB and let me know!
Old Jan 12, 2004 | 07:15 AM
LSC5.0HO's Avatar
FIRI VP
yep, when I did the swap, I kept the valve cover, and it says 16 valve. I also have a multi port intake that I haven't swapped in yet. Can I slap that intake on, or is there other parts I may need like distributor or engine harness??
Old Jan 12, 2004 | 07:17 AM
LSC5.0HO's Avatar
FIRI VP
Oh, and I think all the d15B1's went 16 valve in 89. I think, don't hold me to that.
Old Jan 12, 2004 | 02:03 PM
U13SER's Avatar
you need the dx or si (MPFI) IM and TB to make that extra HP and 1 other thing you might need is the dx or si map sensor!
