CEL stays lit when checking ecu codes
Old Jan 4, 2004 | 03:30 PM
RedOctober's Avatar
Certifiable User
Default CEL stays lit when checking ecu codes
I was trying to check for any ecu error codes >>b16a3>>US del sol. I jumpered the ecu and when I turned the key the check engine just remained on...answers?
Old Jan 4, 2004 | 04:16 PM
C VeX's Avatar
means No ERROR
Old Jan 4, 2004 | 11:56 PM
crix's Avatar
:mugen member:
does the light stay on while the engine is running ?
IF the light comes on when U jump the wire & does not blink,then there is no problem,......
Old Jan 6, 2004 | 09:28 PM
User1578's Avatar
My blowoff valve goes Moo
Hey, that's only half true. Vapor knows what he's talking about, no flash either means A) No problem or B) ECU...
If the light comes on when the connector isn't jumped, then stays when you jump it... it's your ECU.
Are your revs limited at all? If so, how many rpms?
AIM: IntegrVTEC <-best way to contact me.
Old Jan 7, 2004 | 03:55 AM
mtber's Avatar
To see what a code actually looks like, unplug your map sensor on the top of your throttle body while you have the ecu jumped
To get rid of the code, reset your ecu via neg battery term.
Old Jan 9, 2004 | 08:22 PM
RedOctober's Avatar
Certifiable User
[QUOTE]Originally posted by mtber
[B]To see what a code actually looks like, unplug your map sensor on the top of your throttle body while you have the ecu jumped
I know what an ecu code looks like and have a complete listing of number of flashes to which numbered code. But I have never had my CEL stay on when I have the ECU jumpered.
Old Jan 9, 2004 | 08:53 PM
mtber's Avatar
[QUOTE]Originally posted by 1stEG6
[B]
Stanly, Stanly Tool
Old Jan 10, 2004 | 09:33 AM
RedOctober's Avatar
Certifiable User
ok?
Old Jan 10, 2004 | 09:36 AM
RedOctober's Avatar
Certifiable User
User 1578...Yes revs are limited. Stock ecu, it hasn't been violated.
