Stupid Brake Light!
Old Jan 3, 2004 | 02:43 PM
TRD_Tc's Avatar
Using The Force Of N/A
Default Stupid Brake Light!
I know this is sort of a repost but I cant find the old one. My Brake light on my dash (99 Teg) won't go out. It goes on an off sometimes but for the most part its always on. My brake pads are good and I've got brake fluid so what is it? Maybe my little switch on the E-brake? ,please help. Thanks.
Old Jan 3, 2004 | 03:18 PM
Josh's Avatar
Dr. Doom
yeah, mine does that too, i believe it's the switch on the e-brake, i've never gotten around to checking though.
Old Jan 3, 2004 | 10:41 PM
sone's Avatar
check the float on the brake master cylinder....
Old Jan 4, 2004 | 02:04 PM
Janky99's Avatar
Honda Guru
Your low on brake fluid, i had the same problem,your e brake and brakes use the same light
Old Jan 4, 2004 | 07:39 PM
crix's Avatar
:mugen member:
also check the wiring for the brake light
Old Jan 5, 2004 | 05:43 PM
redshgrl's Avatar
~Superstar~
you're low on brake fluid.... my lude did that for a while, but not anymore
~Melissa~
Old Jan 6, 2004 | 07:11 AM
SpringHill - H22's Avatar
H22 PWNS JOO
yup fill the brake fluid friend had the same problem with his Rx-7 fill it you will be fine
Old Jan 6, 2004 | 05:24 PM
TRD_Tc's Avatar
the brake fluid is Full and the Pads Are Perfect. Its gotta be somethin else.
Old Jan 6, 2004 | 09:21 PM
User1578's Avatar
My blowoff valve goes Moo
Your fluid may be fine, but make sure the floater is floating... mine got stuck down and caused the same problem.
AIM: IntegrVTEC <-best way to contact me.
Old Jan 8, 2004 | 09:52 AM
jimc93si's Avatar
This happens on my 'Teg all the time. The brake light was on solid yesterday, all day, so at 7/11 I held the hood up with one hand, took the top off the brake fluid resevoir with the other. Jiggled the top a couple times to make sure the float was free and screwed it back on, no more brake light. 30 sec. total.
