Rear Brake question
Old Dec 31, 2003 | 02:57 AM
RedBaron's Avatar
Question Rear Brake question
If I'm doing a rear brake swap on a 97 civic ex using parts from 99-00 civic si, do I need to replace the trailing arms? Looking at the helms manual, it seems the brake drums can be removed from the rear hubs and the brake discs installed reusing the hub bearings, spindle nuts and washers. Is it easier to install trailing arms with the brake dics already attached to avoid any headaches? If so, where is the best junkyard?
If you drain it they will come.
Old Dec 31, 2003 | 07:32 AM
Spence's Avatar
"TEAM WHITEY"
I would think the arms would be the same but not positive to save you the headaches go to ace on i-4 and like 40th
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old Dec 31, 2003 | 01:06 PM
dropcivic's Avatar
Redneck Proud
Okay, new parts you need: rear trailing arms, upper arm, spindle, e-brake line, brake hose(i think not postive), rotor and caliper. We just did a 98 civic ex at work and that is what we used.
Honda certified Tech
Southern Pride not racism
Old Dec 31, 2003 | 04:11 PM
RedBaron's Avatar
My list is the same except for the spindle. Where did you get the parts?
Old Jan 1, 2004 | 07:22 PM
KJ's Avatar
KJ
bored at work
I just switch the whole trailing arm. Keep the stock alignment bars and upper control arm. All the trailing arms are the same since 88 pretty much with no major dimensional differences so yes you could do the hub swap but I think it is alot harder to do it that way.
