crx with b16 wont start
i have a crx with a full obd1 b16 swap that wont start. I am getting power every time and my battery is not dead i checked. I turn the key over and i get a really fast clicking noise. I cant figure out why my cqar wont start someone plz help i need my car for 1320. PM me or ansere on i here i will check it.
b16 on the way
b16 on the way
sounds to me like a relay for the clutch or if its a b16swap was the car a automatic,i dont think its the strater but to be shair pull the firing plug and run a wire from the battery to so if it turns MAKE SURE ITS OUT OF GEAR
i love AUTOZONE
i love AUTOZONE
I agree. Iam not sure if this works on all starters but I know on some of the 95 dodge pickups you can hit the starter and try to start it again and repeat, I guess to see if thats it or not.
If you want to manual start the car you can connect a wire from the pos. terminal on the batt. to the starter. THat should start. If not that stater is def. bad. There are other ways to test the starter you could take it off and have like auto parts store hook it up to a voltmeter or ammeter to test the amps.V. Check all your connections to like your ground on the starter itself.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
It could also be a loose connection on the battery. Wiggle them around and go back in and try again. That click click click sounds like a starter though.
if i tap the starter are you saying that it will free up the starter and it will start every time. I have checked the volts and they are at 12.33 that is fine the battery is not dead it is at the same.
b16 on the way
b16 on the way
have some one come look at it then call Crix or even i will come if your around tampa
i love AUTOZONE
i love AUTOZONE
You could take your stater off and take it apart and clean it up with a rag then slap it back on the car and then start the car. lol. It does work.
it does not sound like a starter moslty when the start goes bad it makes whinning noise cause it is trying to spin not chlicking nosie but of course should maybe get it tested but i say its a plug
i love AUTOZONE
i love AUTOZONE
