quick help. .
Does anyone know what pin number the vtec sol. wire goes into on the ecu? I thought it was A17 but its not working and I wasnt sure were I got that from. its a pr3 obd0 JDM b16
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
A8
Gracie Barra Clearwater
Well code 21 is gone but it does not engage any more ideas what to do. The vtec sol. when I apply power to it clicks so it does work. I have a mugen program so the others are not enabled.
IF u have a oil prssure gauge U can check the vtec from the head
there is a bolt on the front of the vtec solenoid,remove the bolt &
install any oil gauge & get a reading,also check the screen on the solenoid,besure it is not clogged,if U can get a haynes/helms manual
it might help...................
813-377-5505
already bought a helms. filter is clean. What if iam not getting the pressure?
ok, another q. is on the CYL Postion sensors are those suppose to be pluged into b10 and b12? or c1 and c2? I ran a wire striaght from the dist. to c1 and c2 to see if it was the wiring? I know on the dx to si wiring its b10 and b12.
