crx wont start..need help!
Old Dec 23, 2003 | 06:14 PM
Rdline1's Avatar
Hi Hi Hi?
Default crx wont start..need help!
ok i have a 91 crx with a b20/vtec swap. got another car as well for school so the crx has been sitting a little bit and now it doesnt start. it cranks like it wants to start but it doesnt. ive checked for spark, which was good, fuel is good, and fuel pump seems to be ok. injector pulse is good as well. tried jumping it too. i have a fuel pressure gauge as well and it reads about 45 psi although the guy who built the motor had it about 60 psi when i left the shop. could the regulator be bad? the fuel pump? or could it be electrical? any advice would be greatly appreciated. i need to sell this car soon. if anyone is interested in buying pm me as well. thanks a ton everyone.
98 Camry w00t! (daily ride)
91' Eclipse GS-t (she's alive!!)
AOL IM: usfbull49
Originally Posted by Frankie
When a jelly fish comes out of my ass, I'll take pics.
Old Dec 23, 2003 | 06:23 PM
crix's Avatar
:mugen member:
IS it OBD-1 ? OR pre 0bd
I CAN FIX IT CHEAP
Let ,me know
Old Dec 23, 2003 | 07:41 PM
MattC's Avatar
Professional Asshole
u just said it was sittinga lil bit, how long is a lil bit? performance machines get tempermental about shit. the car should run on a fuel pressure of 45, chances are ur not getting enough power, if all the things u said are good really are.
Semper Fi
Aim and Yahoo- Inkedupordie
Old Dec 23, 2003 | 09:41 PM
KJ's Avatar
KJ
bored at work
Well think about what you need to start a car.
Compression
Fuel
Spark
Timing
One of the four has to not be there for it not to start. How did you check for spark and fuel? Just because there is pressure at the fuel filter does not necessarily mean it is across the rail also. Check your tuiming belt to make sure it has not skipped a tooth. Check compression.
Old Dec 23, 2003 | 11:35 PM
crix's Avatar
:mugen member:
Compression
Fuel
Spark
Timing
Old Dec 24, 2003 | 05:07 PM
Rdline1's Avatar
Hi Hi Hi?
i unscrewed the end of the rail a little bit, and it released some pressure so i know it has pressure. yet to do a compression test but i guess i could check that too. i pulled the plug wire and plug in #1 cylinder and pointed it at a ground and cranked it a little bit and it sparked so it has spark. did an injector pulse test as well and that came up positive. never thought about the timing belt thing but that might be it too. the car has been sitting for about 2 weeks give or take. i had started it up a couple times and taken it around the block but that was about it.
AOL IM: usfbull49
Old Dec 25, 2003 | 09:23 AM
Rdline1's Avatar
Hi Hi Hi?
AOL IM: usfbull49
Old Dec 26, 2003 | 04:28 PM
sickazz-92HATCH's Avatar
how much psi!!!!!!!!!!!
id let crix work on it he knows his shit pretty well bro
want a smoke and a pancake
Old Dec 26, 2003 | 10:30 PM
i-h8mytruck's Avatar
GONZO SHAPED MEMBER
I had the same problem. You may need a distributor my TDC censor was bad, causing the car not to start.
Did somebody bass tape you?
Old Dec 27, 2003 | 07:53 AM
Rdline1's Avatar
Hi Hi Hi?
i had a friend mention the fuel filter may be clogged too. gonna check these things when i get a chance
AOL IM: usfbull49
