tps on 96 dx with b series swap
Old Dec 22, 2003 | 01:27 PM
StricKlyMT's Avatar
aka civicke96
Default tps on 96 dx with b series swap
Ok here goes when i first put in the motor (B18c1) i was gettin an iacv and tps code recently i talked to cory and he told me how to solve the iacv problem i was to move the pin from A-14 to A-12 at the ecu and that fixed that but i still havent fixed the tps problem and i know the sensor isnt bad as i have tried three other sensors that i know were good i have also sat down and retraced every wire know to man on the entire harness and i see know problems just wondering if anyone else has had this problem and has any input if so it would be greatly appreciated
Old Dec 22, 2003 | 03:58 PM
KJ's Avatar
KJ
bored at work
Is it out of adjustment. Do you have the map and tps plug switched. The tps plug has the red wire in the middle.
Old Dec 23, 2003 | 11:43 AM
StricKlyMT's Avatar
aka civicke96
no there not switched anyone else ever had this prob
"STRICKLY MT" Shop open for business
Tuning available for S300 and Kpro
727-510-6301 Tristan
11.99@116 All Motor K24 Civic Eg6 on Drag Radials
MattBuilt
Old Dec 24, 2003 | 09:08 PM
StricKlyMT's Avatar
aka civicke96
someone help me out
MattBuilt
Old Dec 24, 2003 | 10:49 PM
mtber's Avatar
I recommend turning the ignition on, not the engine... (double click)
Then use a voltmeter & test all the 3 wires running to the tps sensor. Test these wires WITH THE plug plugged into the tps sensor...
The middle red wire should give you 4.5-5 volts at wide open throttle.
Your best solution is a voltmeter & a helms manual.
Happy wiring.
Old Dec 25, 2003 | 02:22 AM
terry.ho's Avatar
I love to choke people.
i have a 96 with a b swap in it. If you want I could possibly hook up with you and you could take a look at my set-up to see if there are any differences. I have no problems with mine. PM or give me a call at the number below.
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old Dec 26, 2003 | 11:57 AM
StricKlyMT's Avatar
aka civicke96
does anybody else have any thing i could try
MattBuilt
Old Dec 26, 2003 | 04:25 PM
sickazz-92HATCH's Avatar
how much psi!!!!!!!!!!!
i go along with what mtber says
want a smoke and a pancake
Old Dec 26, 2003 | 06:05 PM
StricKlyMT's Avatar
aka civicke96
ive done that i get proper voltage and everything its the weirdest thing
MattBuilt
Old Dec 28, 2003 | 10:58 AM
StricKlyMT's Avatar
aka civicke96
anybody else have any other clue on what this could possibly be
MattBuilt
