Honda to produce Jet engines !
Old Dec 18, 2003 | 10:01 PM
mtber's Avatar
Default Honda to produce Jet engines !
http://www.vtec.net/news/news-item?news_item_id=184482
Torrance, Calif. 12/16/2003 -- Honda Motor Co., Ltd. announced today the development of its compact, lightweight, fuel-efficient, low-emissions HF118 Turbofan Engine for the HondaJet-Honda's experimental business jet.
Honda used its proprietary computational fluid dynamics software to optimize airflow within the compact engine, maximizing performance. The engine's simple, high-performance combustion chamber keeps emission levels low enough to meet the requirements of anticipated standards for compact jets.
On the basis of electronic control technology originally developed for automotive applications, Honda has created the first ultra-compact Full Authority Digital Electronic Control (FADEC) system for this class of engine, which provides superior engine operation and reliability without variable mechanisms.
Development of this engine began in 1999, and it has been submitted to comprehensive testing, including required tests such as the 150-hour endurance test. The engine has now logged more than 110 hours of flight-testing on other manufacturers' aircraft, confirming its reliability.
Key Specifications
Engine Type
2-Spool Turbofan
One-Stage Fan, Two-Stage Compressor, Two-Stage Turbine
Take-off thrust
757 kgf (1,670 lbf)
Take-off fuel consumption
0.49 kg/hr/kgf (0.49 lb/hr/lbf)
Cruise thrust
191 kgf (420 lbf)
Cruising fuel consumption
0.75 kg/hr/kgf (0.75 lb/hr/lbf)
Dry weight
178 kg (392 lb)
Bypass ratio
2.9
Fan diameter
441 mm (17.4 inches)
Total length
1,384 mm (54.5 inches)
mtber's Avatar
This is your pilot speaking, please fasten all seatbelts for our engagment of VTEC
Old Dec 18, 2003 | 10:05 PM
mtber's Avatar
Default .
Old Dec 19, 2003 | 04:10 PM
quicksilver EK's Avatar
The one punch machine gun
"yO my boy got one in his civic "
im sure ricers will dream of this ......
97 ITR-Mugen Equiped
04 Honda 600RR
Old Dec 19, 2003 | 04:56 PM
BitbyStreetRacin's Avatar
once your bit, your done.
When are they gonna start making swap mounts for a crx for this killer swap?
Old Dec 19, 2003 | 05:00 PM
mtber's Avatar
bahaha
Old Dec 19, 2003 | 05:49 PM
Josh's Avatar
Dr. Doom
that's my next swap yo!
Old Dec 19, 2003 | 06:15 PM
spoonfed's Avatar
Tha numba one stunna
I already have the prototype in my car
... content in sig not work friendly
Old Dec 20, 2003 | 03:00 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
Why do you all think some people call my car the stealth fighter jet???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
