Stroker kit
Does anyone know how much it would coast to get a stroker kit installed in a 1999 Acura Integra GSR. And Do you think it would be a good plan to add direct port nitrous injection to the car if i got low compression pistions and AEBS sleeves with the stroker kit. please help me out.
you also failed to understand that nitrous loves compression, go ahead and spray a low compression motor, its all bad news.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
what do you guys think about doing this http://www.goldeneaglemfg.com/building.html then adding direct port.
i say golden eagle 2.0 liter 12.5:1 compression ratio,B16 head with some skunk stage 2s, and 100 shot wet should do the trick
owner/operator
owner/operator
This is what you need:
http://www.dartheads.com/hsbalum.htm
