electric load ecu throw code 20
last night i installed my si axles with the dx hubs on them, pumped in the tranny fluid *pumping sux, thankfully it's only 1.9*, did the usual checks, primed, started, and then took my car for it's first ride with the engine. *yes I was nearly in tears again*
one of the codes, 3 in all, it decided to throw was an electric load code.
we will have George *wiring guy* look at this also, but i was wondering if any of you have experienced this code. KJ?
thanx..angela
thanx..angela
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
what other 2 codes are flashing ?
code 20 is (ELD) Electrical Load Detector Bad fuse box under hood
Thats probly not the probem,PM me IF U need help........
813-377-5505
i was half asleep when spaceman dan stopped by with his pure oem crx. he mentioned the alternator as well.
maybe we used the alternator that went bad from zmr *NOT thier fault, i bought a used/as-is one from them* and not the one i got from BJ. we'll have to exchange them out and see what happens.
the codes were...
3 - map sensor *we knew this one would prob come up due to using the Y8 and moving the sensor*
17 - speedometer *oops, i didn't do it right*
20 - electrical load
*if i got 3 and 7 confused...sorry*
the codes were...
...91 SMF SCCA
dayum sorry 17 not 7
...91 SMF SCCA
sounds like wiring problem,is it OBD-1 ?
map is not the problem(unless its bad) mine is the same way
The Batt.. light will be on if the alt....was bad(gauge pod batt. light)
813-377-5505
Either a break in wire at b19 or like Scott says bad fuse box (not fuse the whole box).
Gracie Barra Clearwater
i got a obd0 crx throwin code 20 and the check engine light starts flickering and the car stalls and wont start let and its intermittent
-jay
-jay
