Wiring up low beams...Help!!!
Old Dec 13, 2003 | 02:47 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Default Wiring up low beams...Help!!!
I am trying to wire up some low beam 9006 bulbs without using the OEM harness (long story and don't feel like explaining!).
I'm planing on using a Pilot Foglight harness and a single inline 20amp fuse.
Each bulb has a 10amp fuse dedicated to it in the stock fuse box.
The only problem is that the foglight harness has only one wire leading to the bumper...then splices out to two wires for the positive, So I can't run two seperate 10 amp fuses at the end of the lead right before the bulbs.
Instead of me running another wire to the front and using two 10amp fuses...Can I use one 20amp at the beginning of the positive or ACC lead instead and be done with it?
I just don't wanna fry anything and these bulbs I just got are expensive as all hell and I can't afford to kill them and keep buying new sets, They are of a limited addition series.
Thanks in advance for your electrical knowledge.
-Jeff
BTW: I hope this discription makes sense. Haha
My Flickr
slam.poke.drop.tuck.dope
