oem pistons with eagle rods?
Old Dec 10, 2003 | 07:34 AM
gotvtec20's Avatar
Import Tuner
Default oem pistons with eagle rods?
Just a wonder, can you use oem pistons with eagle rods and not have to make any adjustments?
03' BMW 330XI
Old Dec 10, 2003 | 08:28 AM
99B16Si's Avatar
will not work without custom machining. the eagle rod uses a free-floating wristpin and requires c-clips to hold the wristpin in place. stock pistons do not have a groove for a c-clip and this will cause the wristpin to eventually hit the cylinder walls and destroy your motor.
the stock honda rod uses a pressed wristpin and does not require c-clips
Old Dec 10, 2003 | 08:56 AM
i-h8mytruck's Avatar
GONZO SHAPED MEMBER
PM rain and he can tell you why it isn't a good idea. He ruined his LS/VTEC setup by doing this.
Did somebody bass tape you?
Old Dec 10, 2003 | 11:50 AM
NChatch's Avatar
i stepped on my weiner!
yeah they seems to sound like someone dropped a bunch of hammers down in your motor, i had a friend who did this on accident one time, total motor loss
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Dec 10, 2003 | 02:51 PM
gotvtec20's Avatar
Import Tuner
Tru. Thanks guys. Yea I am moving to the next step in an engine i am building. I guess i can just stick with the oem rods and get some arp rod bolts.
03' BMW 330XI
Old Dec 10, 2003 | 03:27 PM
vertigo_16201's Avatar
the wrist pin goes with the piston not the rod... use stock piston with stock wristpin unless aftermarket wristpin diameter is different or something?
Old Dec 10, 2003 | 06:44 PM
na200whp's Avatar
Powered by BOOST
oem rods are press fit and eagle rods are free floating .the will not fit. an oem wristpin free floats in the pston not the rod.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Dec 10, 2003 | 06:47 PM
Ur right, stupid me.. i just checked my old pistons/rods, the wrist pin is pressed into the rod not the piston, stupid me
Old Dec 11, 2003 | 05:42 PM
specie's Avatar
only work if you're using h22 rods; not sure what motor you're building.
