how good
Old Dec 3, 2003 | 05:30 PM
prican's Avatar
Default how good
how good is a tdo5h turbo on a stock del sol eng. and how high can i boost it up...also what would be good for me too do?????around how much hp wil i get with the tdo5h turbo, fmic? will an ls fule pump work enough for me????
Old Dec 4, 2003 | 04:47 PM
prican's Avatar
i still need help?????
R.A.P.S member number #0006
Rotaries
Against
Piston
Swaps
msn: prican8069
yahoo: ltorovelez
aim: ltorovelez
Old Dec 4, 2003 | 05:09 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
on a stock single cam i would only suggest around 5 psi or so and you should definately upgrade your fuel if you plan on boosting higher in the future.... right now to only boost about 5-6psi on your stock motor you shouldnt need fuel upgrades except for maybe a pressure regulator or somethin along those lines... stock pump and injectors will do the trick... if you want to do it right though, i suggest saving your money and either get a swap or start building the single cam motor... give me some more info on what your goals are and what modifications you currently have as well as those you plan on making, and i will try to help you out to the best of my knowledge....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Dec 4, 2003 | 05:38 PM
prican's Avatar
i have an ls fule pump.....should i shange the pistons or what should i do i want to get the best out of tha single cam is an si
Rotaries
Against
Piston
Swaps
msn: prican8069
yahoo: ltorovelez
aim: ltorovelez
Old Dec 4, 2003 | 05:41 PM
Retired Ricer...
i would at least get aftermarket rods suck as eagle or crower, and some low compression pistons like JEs or somthing..... this will give u a little more to play with... build it right the first time and you should be happy with the results
Old Dec 4, 2003 | 05:49 PM
prican's Avatar
around how much the pistons and rod cost me.......also is the ls fule pump good enough????? will i need injectors????
Rotaries
Against
Piston
Swaps
msn: prican8069
yahoo: ltorovelez
aim: ltorovelez
Old Dec 4, 2003 | 05:54 PM
pressuredsol's Avatar
Pleasure the do me
450's, afc, manifold, piping, intercooler, a/f gauge, boost gauge, boost controller, and alot of patience.
