ECU Need some really good help. .
Old Nov 28, 2003 | 06:31 PM
civicracer901's Avatar
B16ACRX
Default ECU Need some really good help. .
I bought this 5spd pr3 with a mugen chip with sensors disabled. Iam still redlining at 7grand and the only thing I can feel differnce on is the car runs rich now which I like. Iam really having a hard time trying to figure out what is wrong?, why iam so stuck on 7grand. I reseted the ecu pulling the fuse under the hood fuse box. Its supose to have no rev. limiter and vtec engagment of 4500rpms.
I bought the ecu from a well respected and honest person. I know nothing is wrong with this ecu.
Iam still throwing codes 9,23 The vtec I have not ran the one wire yet but it still should go past 7grand. Iam really stumped.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Nov 28, 2003 | 07:27 PM
crix's Avatar
:mugen member:
CODE 23 IS KNOCK
IT MAY NOT BE CHIPPED TO ERASE THESE CODES
CK PM...........
Old Nov 28, 2003 | 08:31 PM
mtber's Avatar
Code 9 is a serious code... CYP Sensor (Cylinder)
Try rulling these codes out by trying a different ecu, you might have a bogus ecu
What wire havnt you ran ? All wires should be ran before you go testing a car....
Old Nov 29, 2003 | 12:14 AM
specie's Avatar
run all the wires first. I believe the Mugen program eliminates the knock sensor and the secondary 02 sensor.
Old Nov 29, 2003 | 12:40 AM
crix's Avatar
:mugen member:
ALL wires R run Knock ,Oil press.,oil pess..ground,V-tec,both 2s"s
are there as well in the Correct Location
A-8...VTEC
B-5..OIL PRESS...
C-2ND...O2...GREEN
B-19..KNOCK.....
C-16......WHITE
DID THIS MYSELF
iKNOW I DID NOT DO ANY THING
BEcause Ive done this over 100timeS
PM ME ASAP
JOMON................
