power windows won't go down!!!!ARG
ok my friend has a 93 lx, we has just recently installed a system in it, i was not there for the initial wiring and such, but while i was there they had removed part of the dash(the ash try and lighter part) that had exposed wires and such, they ran the wiring along the side of the car and under the carpet, used the wiring kit and made a clean install and what not, wired the amp to the battery, unplugged his fog lights he had wired also (still unplugged), took off some of the door panels, but now all of a sudden only the drivers side window will go up and down, the switches on the drivers side panel will not work for the other 3 windows nor will the ones on the doors them self work.
ask me some questions if this does not make any sense, tried to give an explanation of what was done prior to this problem.
thanx
thanx
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
ohhh boy, its time to pull out a wiring diagram on that vehicle & a voltmeter.
ahh crap, i was hoping thats what we wouldnt have to do!
i guess we'll have to look even closer to see if we went over any wires that we hadnt checked to see if we cut them, but 3 doors that dont work?..hrmm the power locks still work and such, but just not the windows, hmmmmm.
