H22A1 Boggin HELP ME PLZ!!!!!
Ok, I Have a 94 Si Lude with an h22 swap. THe car was running fine until I got back from my trip to NJ. I noticed after putting gas In GA it began to bogg on me. It keeps on doing it. It happens when I try to punch it or just coast. Its a slight hessitation but its there and it even goes in with the VTEC. WHat to do? I looked at the cap and rotor, wires I ran fuel treaments. Please help. IF you want to call to explain 941-286-4966 Thanks
Only thing you can do is standard testing.
1. Check for any codes.
2. Compression Testing
3. Ignition Component replacement (cap, rotor, spark plugs, wires)
4. Just diagnose the whole motor from the ground up... :-/
[QUOTE]Originally posted by mtber
[B]Only thing you can do is standard testing.
I can fix it very easy,
PM me IF U want it repaired,for cheap............
813-377-5505
pointing at myself. Well i did the fuel filter and plugs and that eliminated my problem. Thanx gents. I should have started to diagnose it on my own. However, this is my First VTEC motor so I really dont wanna fk anything up. Thanks again. BTW, I am looking for a superchager for a h22a let me know thanks
