motor not starting..help..
Old Nov 19, 2003 | 02:37 PM
Juiced_Sol's Avatar
LS1FTW
Default motor not starting..help..
Ok my swap is almost done except that i have no fuel or spark, but the engine cranks over. Their are two plugs not connected(on the motor harness) and theirs only one plug on the car harness, but it doesnt match up. I know the two plugs are important, and need to be used. But I have no clue were id have to wire it...
Is their a conversion harness i need to get or iam i going to have to wire it myself. If I have to wire it myself does anyone know someone good that can do this fairly cheap...
Its a obd1 b18a1 swap going into a obd1 93 del sol.
thanks....
Old Nov 19, 2003 | 07:24 PM
mtber's Avatar
You're not making much sense buddy :-/
Take pictures, & make a more clear post.
Old Nov 19, 2003 | 08:27 PM
crix's Avatar
:mugen member:
are you using the del soul harness stil?if so you will not need a another harness........do you have an obd-1 dizzy?? And what 2 wires are you talking about?
Old Nov 20, 2003 | 03:31 AM
Juiced_Sol's Avatar
LS1FTW
Im using the b18 harness, which is being plug into a 93 del sol harness. The two plugs i think they are (not pluged in) the fuel pump, and the ingition system. Since when i loosen the bolt on the fuel filter and tried crankin it, no fuel came out. Then i put a thin screwdriver in one of the spark plug wires, then cranked it no light/ spark from it. Ill get some pics as soon as get home from work. Also both harness are obd1 and the dizzy also.
Old Nov 20, 2003 | 12:28 PM
crix's Avatar
:mugen member:
try using the del sol harness,then it WILL Start!.....
Old Nov 20, 2003 | 01:22 PM
Juiced_Sol's Avatar
LS1FTW
b18a1 harness on motor (front view)
Old Nov 20, 2003 | 01:23 PM
Juiced_Sol's Avatar
LS1FTW
b18a1 motor harness (side view)
Old Nov 20, 2003 | 01:25 PM
Juiced_Sol's Avatar
LS1FTW
93 del sol plug that goes to fuse box
Old Nov 20, 2003 | 01:26 PM
Juiced_Sol's Avatar
LS1FTW
93 del sol another angle, these are the only plugs left, but none match up.....
Old Nov 20, 2003 | 04:13 PM
mtber's Avatar
Try using you're delsol harness.
If this fails have some one that knows what they are doing come over & help you....
I am in Palm Harbor, which is prolly far from ya...
