question on vtec problem
Old Nov 16, 2003 | 05:16 PM
Sunrise City Rider's Avatar
WHAT!?! OK!......
If Vtec engages and its not as strong, check your timing and check your compression...It sounds like you have lost compression in one of your cylinders...
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old Nov 16, 2003 | 05:55 PM
crix's Avatar
:mugen member:
IF its a timing problem iTS repairable,IF its losing power
do to bad piston rings you might need a rebuild........
Old Nov 16, 2003 | 06:46 PM
mtber's Avatar
Things you should do:
Compression Test
Leak Down Test
Replace Ignition Plugs
Check oil pressure
