B16a Head Problems
Old Nov 13, 2003 | 04:31 PM
BitbyStreetRacin's Avatar
once your bit, your done.
Default B16a Head Problems
I've had this problem for a while now ever since I got the car. The valves click really loud, I had a crooked exhaust CAM GEAR, and when I upshift into a higher gear at low rpm and press the gas more than a 1/6th of the way down, it clicks very loud, a wierd sounding click. Pressing the gas more than like 1/6th of the way down also makes this noise in any gear until about 3500+ rpms. I dont rev past 5k because when I do, bad things happen. The spark plug seals will leak, and the cam gear rubber bushing thingy works its way loose and leakes oil down to the header then goes splash. I think this may have been due to the crooked cam gear woobling so fast at that high of an rpm, then when VTEC engages, just fuckes everything up. Also, the car smokes very bad. It doesnt have a cat, but I know that isnt the whole smoke problem. I honestly cant tell what color the smoke is, I'm thinkin grey/black and it smells bad. And Im getting shitty gas mileage. What could be causing this in my b16's head? milled cams? bent valves? bent cam? I need to know and get it fixed asap.
Old Nov 13, 2003 | 04:48 PM
Strongest Man In The World's Avatar
Embrace the Hate
sounds like you need a valve adjustment to correct the clicking. and you valve guides seem worn if the spark plugs get oil in them, what do you mean crooked that the cam gear is bent or the timing is crooked(off0) ethier way get a new cam gear and reset it to tdc.
CombatFitnessBlog.com
Click ^^ to receive the controversial Ebook "Maximize Your PT" for FREE
People fear what they don't understand, hate what they can't conquer. Guess it's just the fury of man!
Who are the Hardcore lifters?? StrengthCamp RyanMagin.com
Old Nov 13, 2003 | 05:57 PM
one of the spokes on the gear is cracked to that spoke bent inward a little now when it rotates it sorta wobbles. That couldnt have caused bent valves could it?
Old Nov 13, 2003 | 06:50 PM
oh yes forgot to mention head is totally built with skunk2 internals and Type-R cams...
Old Nov 13, 2003 | 08:04 PM
KJ's Avatar
KJ
bored at work
Fix it ASAP before the bad harmonics fuck up the cam journals and ruin the head. Somebody give this guy a set of stock gears so he doesn't blow a good b16a head.
Old Nov 13, 2003 | 09:12 PM
Joe's Avatar
Joe
Sodalime is good.
Why don't people ever quit rednecking their hondahs and bother to actually take a car to a shop where people that know what they are doing can hear the sounds themselves and give an answer? This whole... 'i hear clicking' shit is getting old and useless.... there are SO many things that it 'could' be...
Joe
Originally Posted by President Abraham Lincoln
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Socialized Medicine?
Originally Posted by a former president of the US
One of the traditional methods of imposing statism or socialism on a people has been by way of medicine. It's very easy to disguise a medical program as a humanitarian project.
Old Nov 13, 2003 | 09:17 PM
rangcrx's Avatar
engine building &best
arnt typeR cams different if this is a first Gen b16?
i love AUTOZONE
Old Nov 14, 2003 | 08:00 AM
99B16Si's Avatar
what
yea sounds like u need to take this to someone to get fixed asap. i have a set of stock cam gears if u want them and ill even fix it if u need me to. goodluck
Old Nov 14, 2003 | 02:03 PM
This is the kind of shit i hate myself for, for getting other peoples rigged out bullshit motors. I will never get another motor from any one but a company that sells them. I took some pics for some of you to check out, call me a noob but the intake cam has an E on it, does that mean exhaust? :ugh: Im gonn try to get a cam asap so if anyone is bored and would like to help me out, tell me! 99B16Si, that sounds cool how much for the cam gears and such?
Old Nov 14, 2003 | 02:11 PM
http://www.bitbystreetracin.com/thecar
heres some recent pics of underneath the valve cover.
im in need of a valve adjustment bad after i get the new gear(s)
