rocker arm ?
Old Nov 12, 2003 | 10:10 AM
jdmef9's Avatar
Default rocker arm ?
i had a ticking in the so i pulled the valve cover and saw i was missing a nut on 1 of the rocker arms so i got a new 1 put it on and it still makes the same ticking noise r there any other things that go on the rocker arm besides that 1 nut please help ill even go to your house so u can
see what im talking about
thanx josh
josh
14.7@91 sohc all motor
Old Nov 12, 2003 | 10:11 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
the ticking is probably the nut that was missing......
tamparacing.com
Old Nov 12, 2003 | 10:23 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Do a valve adjustment, it's probably just valve tap.
Old Nov 12, 2003 | 10:24 AM
Josh's Avatar
Dr. Doom
that's what i was gonna say.
Old Nov 12, 2003 | 12:27 PM
Bill's Avatar
Livin' in Seattle
I don't know how you can sleep at night knowing there's a loose nut floating around your motor...
First thing I would do is pull the pan and check for the nut. As for the ticking, if you just replaced the nut without specing the lash, that would be the culprit.
Old Nov 12, 2003 | 12:43 PM
KJ's Avatar
KJ
bored at work
I've seen this before. Take the valve cover off and pour several quarts of oil directly onto the valvetrain and oil galleys. Drain the oil and search for your nut. If you don't find it take off the pan and windage tray and it will probably show up.
Old Nov 12, 2003 | 01:00 PM
mtber's Avatar
wow that is scary
Old Nov 12, 2003 | 02:02 PM
Bill's Avatar
Livin' in Seattle
In hindsight, before pulling the pan I'd simply drain the oil and poke around in it with a magnetic probe. If that doesn't find the nut, then I'd yank it.
Old Nov 12, 2003 | 02:04 PM
NonVtecEG93's Avatar
Try doin a valve ajustment to the valve thats ticking.
Old Nov 12, 2003 | 02:10 PM
99B16Si's Avatar
yea man, you are extremely lucky, that nut could have done some serious damage. i wouldnt drive it till i found that nut, thats just me tho
