Strut placement correct?
Old 11-06-2003, 01:12 PM
Spent more money than you
The Spectacle's Avatar
Default Strut placement correct?
Mechanic was supposed to install camber kit today. Took off tire and saw this:
Said the first arrow is supposed to be down where the second arrow is and I should have it checked @ the shop that did the install for me. Just wanted to run it by you guys and see if I could get a second opinion. By the way that's Neuspeed sport spring on Tokico HP strut
Racing Integration
LHT Performance
My tuner is named Alpha
Old 11-06-2003, 01:31 PM
mtber's Avatar
The strut has a notch on the back side of it to line up with the suspension fork's gap.
So, there is really only one way to install the strut.
(the only way it will sit all the way down onto the fork)
Old 11-06-2003, 01:52 PM
WHAT!?! OK!......
Sunrise City Rider's Avatar
Just loosen the 14mm bolt and give the strut a shake...It will drop down as far as it will go, then just tighten it up...
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old 11-06-2003, 02:09 PM
so is it installed correctly?
Old 11-06-2003, 02:29 PM
TR Balla Donor Supreme
Vito_Corleone's Avatar
No, you need to slide it down until it won't go any farther, it needs to be resting on that lip thing.
Old 11-06-2003, 02:30 PM
aight.... back to Racingzone for me
Old 11-06-2003, 02:31 PM
Are you retarted?
Old 11-06-2003, 02:33 PM
my bad. i hit back button to many times
OK, np, so you get it now right?
Old 11-06-2003, 02:34 PM
yes sirrrr........
