opinion
Old Nov 8, 2003 | 09:31 PM
F4A22's Avatar
Old School
turbo and i'll never go back
Old Nov 9, 2003 | 05:03 AM
Echo7847's Avatar
turbo...
Old Nov 9, 2003 | 05:40 AM
Sunrise City Rider's Avatar
WHAT!?! OK!......
Originally posted by Vito_Corleone
Well that could go either way, you could say leave the turbos for the engines that were built for it as well. . .
And the LS motor is more ready for turbo than the Vtec Motors...
Just like the Vtec Motors are more ready for Revving than the Non-Vtec Motors...
Did you read his post?
He asked for turbo LS or LSVtec, not Internals and Engine Management and Sleeves...
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old Nov 9, 2003 | 05:53 AM
m0nk3y's Avatar
pwns.
I was just pointing out that it isn't made for Vtec OR FI.
Vito_Corleone
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Old Nov 9, 2003 | 06:24 AM
WHAT!?! OK!......
And your point for pointing that out is?
04 Civic Si
01 Lexus GS300
Old Nov 9, 2003 | 07:25 AM
99B16Si's Avatar
turbo ls w/ good fuel management....
8psi will yield around 220-230whp and will be very realiable and will last quite a long time
Old Nov 9, 2003 | 01:53 PM
  #17 (permalink)
Vito_Corleone's Avatar
TR Balla Donor Supreme
I gues my point was that the way you worded your answer seemed a little argueable, as you could say the same thing about either answer.
Old Nov 9, 2003 | 03:00 PM
  #18 (permalink)
WHAT!?! OK!......
Well heres the arguement...
Compression on a 98 LS is what? 9.2:1...
Compression on a 98LS with a b16a/b18c5 head is what? 9.6:1; with a b18c1 head 9.7:1...
9.2:1 is favorable for FI on stock Cast Pistons...
Now, turbocharging an LS with say a T3/t04b 50trim stage3 turbine in a .48A/R turbine housing will make 15psi at around 4,200rpm and take it to redline at 7,000rpm with lots of torque from 2,000rpm to redline...Great Street Power...
Now with LSVtec, you have a head that is meant to redline at say 8,500rpm and a bottom end that is meant to redline at say 7,000rpm...Combine the 2 and you have a motor that no engineer will design as it sits...You will first want more compression and upgraded rodbolts to make reliable power...
Now that power is not nearly gonna come close to 5psi on a turbo LS and its not gonna be as reliable either...
So, you use the strengths of the motor...ie, lower compression, low RPM torque...
Instead of abusing the block with high RPM...
04 Civic Si
01 Lexus GS300
Old Nov 13, 2003 | 05:57 AM
  #19 (permalink)
skunk2eg's Avatar
I miss my cx motor
good point
***!! will pay $$$ for: Black GSR leather front seats and a 92-95 hatch black cargo cover !!***
Old Nov 13, 2003 | 07:02 AM
  #20 (permalink)
I agree with everything you said. I was never arguing that the Ls/Vtec was, by any means, a better choice, just that the initial wording of your respone was a little confusing.
