tranny leak from rear
i have an tranny leak coming from where the shift linkage goes into the back of the tranny...its a 99 ls swap in my 97 civic.....is that somethign i can fix easily? or do i just keep filling it with oil bc i'm not buying a new tranny?
let m eknow
parker
let m eknow
parker
The seal on the tranny could be bad, although they only use RVT silicone between the tranny and bell housing. But from were you say its leaking from it could be your rear main seal. Which is semi easy to fix if you know what your doing. Either way to fix the leak the tranny gonna have to come off.
Dosent sound like the rear seal or the case. I bet it is the shift rod seal or the rod is bend. Tend to leak when they get bent. Tranny will have to be removed to fix, but if it only leaking a small amount I dont see any need to fix until you plan on doing another major imporvment such as clutch or lsd.
"Friends LET friends get MULLETS!"
