CV Joints
Last week I replaced the passenger side outer CV boot on my 96 teg. Today it started ticking again. I looked under the car and the new boot had split. What possible made the boot split. It was a complete boot not the cheap ones that you enclose with screws and nuts. Just so you know this isn't my first time so I have plenty on machanical knowledge.
Is their to much play in the CV joints or did I fasten the clamps to tight. HELP!!!!!!!!!!1
Is your car lowered?
What motor mounts do you have?
When is the last time you had an alignment?
I would just spend the $75-80 and replace the axle and make sure you check the rest of your suspension components.
I dont know how your boot ripped again but once it starts ticking the damage is done, you need to replace the axle to stop the ticking.
"A good friend will come and bail you out of jail, but
a true friend will be sitting next to you saying,
That was f#&%ing awesome."
just buy some napa axles buddy
i would definitely suggest replacing it and if u can roll the car up on ramps so u still have a load on the suspension and get under the car and thouroughly inspect around the boot to see if anything is anywhere close to it that may rub while driving....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
there is nothing wrong w/ napa axles
I used them in my ek9 w/ a b18b & spray & never had an issue.
