ls motor bogs down at 5k rpm
Old Oct 22, 2003 | 07:55 AM
skunk2eg's Avatar
I miss my cx motor
Question ls motor bogs down at 5k rpm
just got a 98 ls motor in an eg civic. runs great, except when i hit between 4 and 5 k rpm. could it be a bad distributor? incorect timing? or could it be since its obd 2 and i have no o2 sensor? thanks for the help.
***!! will pay $$$ for: Black GSR leather front seats and a 92-95 hatch black cargo cover !!***
Old Oct 22, 2003 | 08:20 AM
Juiced_Sol's Avatar
LS1FTW
the no o2 sensor whould throw up a code (i get one), but bad distributor would defently cause a misfire, or timing is off.
Old Oct 22, 2003 | 10:03 AM
91Crx but i heard vtec's Avatar
All Socoms CAMOPIMPIN
yeah timing is what i would check first after u check the codes that it is throwing after u get the codes out of the way then see where u stand but when u say it bogs at 5000k rpms does it go past 5 or stop there or bog from 4-5 then its fine good luck getting it up and running right
DONT SLEEP's penis tastes soooooo good
Old Oct 22, 2003 | 12:07 PM
Juiced_Sol's Avatar
LS1FTW
nice run-on sentence j/k
Old Oct 23, 2003 | 07:57 AM
skunk2eg's Avatar
I miss my cx motor
yeah the code is a 41, which is o2 sensor. but the problem is it goes past 5k but when it does theres no power
Old Oct 23, 2003 | 08:11 AM
Josh's Avatar
Dr. Doom
o2 sensor
Old Oct 23, 2003 | 09:30 AM
Juiced_Sol's Avatar
LS1FTW
get a o2 sensor, that should fix the problem. Its probably running rich at high rpm since it cant detect you a/f
Old Oct 23, 2003 | 01:37 PM
i dont know if just a o2 sensor would cause that. its definitly possible since its on and odb2 car they suck. when my oxygen sensor went bad it didnt do anything but get a little worse mpg. all cars are different good luck
Old Oct 24, 2003 | 06:06 AM
racin's Avatar
ZMR
Default yo
Ur right not having a o2 shouldn't cause that to happen....drop it off on monday nick so we can tap ur pipe for a O2 sensor and swap out dizzy to see if thats the problem...timing is ok already checked it...but will go over again on Monday.....
ZMRacin...for the people since 1998.
typeZ zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
