swap help
swap help
ok im swaping a b18a1(from a 92 teg) into a 93 del sol. My problem is the mounts from the integra motor dont seem to be lining up to mounts on the chassis of the del sol. As of now i have the tranny mount bolted up, but the rear mount and the driver side mount arent linging up.
Do i need aftermarket mounts, but it suppose to be a direct-bolt in from what ive read.
You need mounts from either a 94+ integra.
Upper tranny mount
rear tranny bracket
front tranny bracket
drivers side bracket
drivers side mount
94 del sol vtec A/C bracket if you want to keep A/C
Upper tranny mount
rear tranny bracket
drivers side mount
Guest
Posts: n/a
|\|0, 17 15|\|'7.
d3l 50l 5h4|235 ch45515 \^/17h 94+ 1|\|73g|24. y0u |\|33d 94+ 1|\|73g|24 |234|2 L b|24ck37, 4|\|d y0u |\|33d 7h3 m374l b|24ck37 7h47 7h3 m0u|\|7 b0l75 70 0|\| 7h3 m070|2 d|21v3|2'5 51d3. L0\^/3|2 m0u|\|75 y0u |\|33d 93+ D3l 50l v73c 4/c b|24ck37 70 |23741|\| 4/c, 1f |\|07, 4|\|y 94+ 4/c b|24ck37 \^/1ll \^/0|2k
Guest
Posts: n/a
Originally posted by Juiced_Sol
But the motor is off a 1992 integra isnt that the same chassis too. i have both mounts sets from the del sol and the 1992 integra.
You need 94+ b series
fuck thats why it aint lining up, the shitty part is i just bought new mounts for the 92 teg hopefully i can return. Anyway i can get all 94+ teg mouts and be good, does it matter also if its b18c or b18b1 mounts(if a difference) from a 94+ teg
