GSR head on B16 block????
ok cool... well that is a good point the flow IS alot better on the B16 im told so now that thats cleared up were cool....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Guest
Posts: n/a
The heads flow pretty much the same.
There are very few differences when matched up on a flow chart.
The GSR head will drop a B16's compression .2, the other will raise .2, It is a useless swap, unless you want to boost the B16 w/ GSR head, then I suppose it's not completly useless.
However, .2 is meeger when relating to boost.
Guest
Posts: n/a
the gs-r head on b16 will raise the comp .2 not lower it. it lowers it when you put the b16 head on c1 block. i thought we went through this already jeff. remember the thread? charles had to get the "white paper" on it. remember the b16 head flows 5.25% more than the gs-r. so that means that it would drop comp because of the quench area being bigger. a bigger combustion chamber will lower compression.
thank you
-Penis
thank you
-Penis
LOL....wow thats somethin ive never heard before.... LOL
