help my brake lights wont go out
Old Oct 20, 2003 | 04:43 PM
blazin85's Avatar
Question help my brake lights wont go out
Hey ppls the brake lights on my 92 integra wont go ou and i dont kno what to do so i just unplugged the bulbs n e help would be helpful thanx
Old Oct 22, 2003 | 10:05 AM
91Crx but i heard vtec's Avatar
All Socoms CAMOPIMPIN
also did u change anything witht he lights or wiring lately if so that might have something to do with it just a idea
DONT SLEEP's penis tastes soooooo good
Old Oct 22, 2003 | 08:01 PM
Insedanity's Avatar
Check connections, bulbs, fuses and switch (under the pedal). If bulbs and fuses are good the switch might be bad. Not sure if these go on hondas but I have had the switch go bad on other cars.
Old Oct 23, 2003 | 06:44 AM
CIVICMAN's Avatar
the switch is off the pedal. at the top of the pedal look for a switch that has a couple wires going to it. it might be loose or just hangin there.
So many cars, So little time......
03 Accord
93 300Z Twin Turbo
Old Oct 23, 2003 | 11:33 AM
Juiced_Sol's Avatar
LS1FTW
take your foot off the brake pedal... j/k, after that check the wires leading to the pedal like eveyone else said. Also the switch behind the pedal could be jamed.
Old Oct 24, 2003 | 06:20 AM
racin's Avatar
ZMR
There is a switch behind the pedal and there is a plastic plug thats on the pedal itself...without the plastic plug on the pedal the switch goes through the hole on the pedal and ur brake lights stays on all the time.....the plastic plug just broke....go to honda or acura you can get one for around $3-$5....
ZMRacin...for the people since 1998.
typeZ zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
Old Oct 24, 2003 | 02:36 PM
blazin85's Avatar
thanx for the help i went to brandon honda and got the part to fix it thanks for the help
